Why do I keep losing IAC Motors??
Old Aug 5, 2005 | 11:36 AM
Silver 2002's Avatar
I just replaced my 2nd IAC yesterday in the past 4 months. It was the 3rd I have replaced since I had the truck in 3 years. The truck starts to make this weird noise (like when you blow into the end of a bottle), a howling sound. When it first starts it just does it a little at start up and then it begins to do it when your driving. Usually you can hit the gas a little firmer and it will stop. Anyway, back to the point...What is causing this! My local Ford dealership called Ford Support and Ford told them that they have some problems on Modded Lightning's and Cobra's because more air is going through the IAC than it can handle and it goes bad. Do you guys buy this? Look at my sig for all my mods!! Thanks for any help you can give me!
Old Aug 5, 2005 | 12:51 PM
whip's Avatar
Mine just started doing it about two days ago. Its my second one. I hear you can just take it off shoot it with carb cleaner, and reinstall. Might be worth a try. I don't know why it does it though?
Old Aug 5, 2005 | 01:00 PM
TriPodRacing's Avatar
Are you running straight water?
If so you need to put some lubricant in the water ,like antifreeze, to lubricate the pump.
Old Aug 5, 2005 | 01:19 PM
LightningTuner's Avatar
Step AWAAYYYY from the bong.....
Old Aug 5, 2005 | 01:25 PM
Sal are you saying the IC pump doesn't need lubricant?
Just wondering cause the water pump on the motor does.
If I am wrong let me know.
Old Aug 5, 2005 | 01:41 PM
SVTJAY's Avatar
IAC - Idle Air Control.... not IC!!!
Old Aug 5, 2005 | 01:55 PM
I was just joking with you. He is talking about the Idle Air Control on the upper intake.
Old Aug 5, 2005 | 01:58 PM
Originally Posted by SVTJAY
IAC - Idle Air Contorl.... not IC!!!
WOW its hot out today!
Ok I threw all the drugs in the garbage.
Old Aug 5, 2005 | 02:00 PM
Yeah my bad I guess I can't do more then one thing at a time.
No more speed reading posts.
