Franken-Plenum testing/ Flame on
Old Aug 4, 2005 | 07:45 AM
olefafl's Avatar
With the stock one on when I went into boost, it would go to 7psi vacuum. This is at the upper, where the pvc valve goes in.
With F-P it would go to 2psi vacuum.
If I am thinking right, that is a better flow? Does that mean that the upper is flowing almost as much as the blower wants?
Old Aug 4, 2005 | 08:48 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Where are the recharge lugs on the neck?
Old Aug 4, 2005 | 09:01 AM
olefafl's Avatar
I couldn't get the alum. bolts in time. They may be added later.
Old Aug 4, 2005 | 10:28 AM
brain bypass's Avatar
lower vacuum readings under WOT would definately mean a decreas in restiction. i didn't think it looked half bad when you made it. i would have smoothed the welds more, but hey function over form any day.
you just had to paint it green and put frankie on there didn't you! LOL now you need a franken-eaton to go with it.
Old Aug 4, 2005 | 10:31 AM
SVT F15O's Avatar
That was my only good song..........
Old Aug 4, 2005 | 10:35 AM
ZorPrime's Avatar
NOW THAT IS FUNNEH!!!!!!!
halcyon's Avatar
...whos the old guy...?
Old Aug 4, 2005 | 10:59 AM
coopersunc's Avatar
Edgar Winter. Johnny's less-talented brother.
Pretty funny!
Old Aug 4, 2005 | 11:05 AM
LightningTuner's Avatar
Dude, that the funniest thing I've seen in a long time!
You get two
Old Aug 4, 2005 | 11:50 AM
ICULOKN's Avatar
Thats one of the coolest things I have seen in awhile... Hope it works good for you!
Old Aug 4, 2005 | 02:00 PM
2bscrewed's Avatar
Too funny!
olefafl's Avatar
Thanks guys.
Can someone with a C&L, and a fab. one do the same test?
Old Aug 4, 2005 | 02:36 PM
Originally Posted by olefafl
Thanks guys.
you would really need to do that test on the same motor.
or at least have someone test theirs stock, and then with whichever plenum it is that they have.
Old Aug 4, 2005 | 02:54 PM
Grimace's Avatar
I like it man. I have a plenum I fabbed up here at work, if you are ever in the OKC area again, give me a hollar and we can swap out my intake onto your truck and see what it does.
Old Aug 4, 2005 | 04:58 PM
typhoon43's Avatar
That's this intake right? I thought you said the fur raised the IAT2's by about 20 degrees. Have you shaved it yet?
