When removing the PSP nitrous plate....?
Old Aug 4, 2005 | 09:49 PM
FLBigDog's Avatar
When I remove the PSP nitrous plate do I need to order a new gasket to replace the ones that were there, or can I get away with using the old one?
If not what is the part number for that gasket, and do most dealerships stock them?
Thanks,
Patrick
Old Aug 4, 2005 | 10:09 PM
Suavy's Avatar
You can reuse the old ones if they are not cracking or damaged in any way. I would suggest using a slight film of sensor friendly sealent on both sides of the gasket.
Peace,
Suavy
Old Aug 4, 2005 | 10:18 PM
FLBigDog's Avatar
Thanks Suavy, any particular product you can recommend, I don't usually get too involved with the engine.
thanks,
Patrick
Old Aug 4, 2005 | 10:48 PM
Suavy's Avatar
Just get your self some seal er from the auto parts just make sure you ask for sensor fiendly. Our trucks have so many dang sensors on them and DO NOT USE REGULAR SILICONE!!!!!!!!
Peace,
Suavy
Old Aug 4, 2005 | 10:59 PM
LatemodelRacer2's Avatar
You should be fine with using one of the stock gaskets. I used gasket maker when i added my plate beacuse it didnt get the extra gasket
Old Aug 5, 2005 | 07:44 AM
booger's Avatar
You can buy the gaskets from Advance auto in the felpro brand,v10 trucks and cobra's use the same gaskets.
Old Aug 5, 2005 | 08:43 AM
Rob_02Lightning's Avatar
I've had my Throttle Body and or Nitrous Plate's, and the gasket's off and on prob a good 50 times over the years. Reused them everytime, never put nothing on it, never a problem......
Old Aug 5, 2005 | 01:13 PM
FLBigDog's Avatar
Nice, thanks Rob. I am removing it tonight.
Old Aug 5, 2005 | 01:15 PM
LightningTuner's Avatar
Like Rob said, you can remove it and reuse it, as long as it's not damaged. I have reused them on my own truck many times.
