FTVB help
Old Aug 3, 2005 | 06:47 PM
282lightning's Avatar
FTVB help
I installed the ftvb today and by accident removed the wrong valve body, three check ***** came out, think they are back in the right spot but could be wrong. The problem is that the truck shifts into 2nd gear really late, at least at 3000 rpm's. If I romp on the engine the rmps go way past 5000rpms and it doesn't shift until I let off the gas a little bit. Also, the overdrive light is blinking. I have checked all fuses and they are OK.
Any help would be greatly appreciated
Mike
Old Aug 4, 2005 | 12:47 AM
Slick_Sammy's Avatar
gregg evans (manufacturer/designer of the FTVB) has been over this several times in detail. try the search feature. i remember seeing this a couple times either here or over at NLOC.
Old Aug 4, 2005 | 01:40 AM
OH-MAN's Avatar
Get a hold of Gregg he has a picture of where they go. There is a total of 4 and two are larger than the others.
Don't ask how I know.
Search may show the locations to put them back.
Old Aug 4, 2005 | 07:47 AM
Yea I have done the searches and have not found the diagrams, I also contacted Gregg Evans and he also told me to search for the diagrams. He said it was in his gallery on f150online but I cannot find it anywhere.
Old Aug 4, 2005 | 02:01 PM
Fear Itself's Avatar
Here you go. I hope this helps.
https://www.f150online.com/galleries...w.cfm?num=3474
David
Old Aug 4, 2005 | 03:01 PM
Talking
I am just letting everyone know that I have fixed my truck. I appreciate all the help I have recieved. I called Lee Myles transmissions in the morning and they helped me out with a diagram on where the check ***** go, put everything back in and now the tires chirp from 1-2 and 2-3. Absolutely an amazing mod for this truck.
Thanks for all the help
Mike
Old Aug 4, 2005 | 08:04 PM
OH-MAN's Avatar
Glad you got it fixed! It is a good feeling to get it back together, Way better than when you take off the wrong one and the ***** drop out
Old Aug 4, 2005 | 10:53 PM
Yea that was a stomach-turning feeling. I was shaking, but then I came here and found out I was not the only one. Shifts real hard now, chirps 1-2 and 2-3, what a good feeling.
Thanks again
Mike
