Why not more 10 second Eaton+bottle trucks?
Old Aug 4, 2005 | 08:53 AM
whip's Avatar
Originally Posted by tallimeca
that's the problem, if i could add up all i've done and could start over from day 1, i would do alot of things different.
Ya, but there was stuff about these trucks NO ONE knew back then! When I bought my two pound pulley I was advised the 4lb was really a RACE ONLY set up. Hehe I remember even a two lb pulley being huge boost.
Hey St Luis.....just keep in mind what that nitrous hit is going to do to your tranny. Be ready to spend some more money!
Old Aug 4, 2005 | 12:42 PM
koopdaddy's Avatar
Wink
Mine will be one of them, at least I hope!!
KB 16 lbs
SVC Long Tubes
No Cats
Magna Exhaust
TB
Intake
SVC tune
3000 Stall 3 disc converter
4.10 Gears
Old Aug 4, 2005 | 12:55 PM
l-menace's Avatar
KB 16 lbs
SVC Long Tubes
No Cats
Magna Exhaust
TB
Intake
SVC tune
4.10 Gears
what size slick?
Old Aug 4, 2005 | 03:17 PM
Rob_02Lightning's Avatar
If I dont wussy out next Sat @ NMRA, I plan on hitting the Eaton with a 150 Shot and see what happens ???
V, YOU ARE BRINGING THE FLAT BED RIGHT
There's A LOT OF THINGS that need to be done in order to go for tens on a consistant basis, just the 15" Bogarts, front and rear suspension work, tall slicks, skinny's, bars, loop, roll bar, proper cooling mods, and tuning, can cost you a good 6K without even talking Motor and KB. Sure you can do it without it, (I hope to in the Fall), but to do it often and consistantly you really need to have it all....
There's much more to it than most think, and at some point YOU WILL cross over the line and give up the factory Comfort, Looks, and Handling. For those doing it, it does appear no money was spared in the building of it, for others like me, I DONT WANT TO cross that line, most still running Eatons prob feel the same way. BUT I STILL PLAN ON TRYING......
Old Aug 4, 2005 | 04:55 PM
whip's Avatar
Rob, hows your truck making out? Haven't heard much from you.
Old Aug 4, 2005 | 06:10 PM
Hey Whip
I dont race in the summer, (making an exception next weekend) But the trucks been running awesome Thanks.
The only issue I've had is burning of plugs, (4 sets down already in like 1500 miles). It's been a tuff balancing act managing the boost levels I'm running (remember I like to run the same tune for the street and track),
and on the street with pump gas, it's a tad too agressive. But we're there now I believe.
Short version, by far it's running the strongest and best it ever has.
Old Aug 4, 2005 | 11:13 PM
Ct.TOPGUN's Avatar
Anyone running a built motor with a ported eaton sc is less than $1000 away from running in the 10 sec range. It is that easy with modern tuning technology.
N20 with proper tuning and slicks and your there.
