Timeserts
Timeserts
Anyone have the part number for the timserts to upgrade to a 8 thread design or a website to purchase them. while my heads are apart i figure i'm going to go ahead and do them
TIA
Will
TIA
Will
Originally Posted by halcyon
If I shoot a plug, roughly how much is the insert job cost?
That issue still worries me.
I heard you can install them with the heads still on the engine, but I'd be afraid of shavings getting in there!
I charge 1 to 1.5 hrs shop labor depending on the cylinder and $8 bucks an insert. This can be done with the head on and I do not leave any debree. I use a bore scope to make sure of that. I can usually repair the coil pack and have you running in about 35 to 45 min.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
He said he does not "leave" any debree.
I'm guessing if there is any, a telescopic magnet could take it out and then re-check the hole with bore scope???
I'm a retard, so dont listen to me... total guess...
Bird
Originally Posted by Bird
These heads are aluminum - magnets don't work. You pack the reamer and tap flukes with grease and it traps 95+% of the chips/shavings and the rest (if any) can be cleaned up with a thin walled tube stuck down the spark plug hole and hooked to a shop vac - very effective.
Bird
Bird
Originally Posted by Spanky99L
Is the 5553 the kit to get and all i need is 3 extra serts?
anyone know where to get em?
Will
Will
