Timeserts
If you order the kit it will give you instructions and tips on preventing/reducing the shavings left behind. One method they had was to use grease in the flutes which works real good. Upon completion of reaming the hole you use a shop vac with some rubber vaccum tubing attached to suck out the debris in the cylinder.
I have the Big-Sert kit. I bought it about 9 months ago and used only 1 of the 5 inserts it came with. If you want it, let me know. Where in Arizona do you live? I live in Tucson, but travel up to Phoenix one a week for work.
