Whipple Woes
Old Jul 30, 2005 | 02:36 AM
Spanky99L's Avatar
Whipple Woes
Well dyno testing of my whipple will have to wait longer. My torque converter began making a lot of noise so i pulled my tranny to send it out to PI. When i disconnected my pass side long tube from the cat cooland came pouring out. So i pulled the pass side head for a head gasket and here is what i found:
Old Jul 30, 2005 | 02:37 AM
Spanky99L's Avatar
More pics here
Will
Old Jul 30, 2005 | 02:46 AM
johnathanh's Avatar
AAAwww damnnnnn sorry to hear that bro
Old Jul 30, 2005 | 08:47 AM
BDAZSVT's Avatar
I think it might be more than a torqu converter!!Holy crap that is messsed up! Was the truck running real bad cause that cylinder is gone completely.
Good luck with the build.
Old Jul 30, 2005 | 09:22 AM
Silver-Bolt's Avatar
Must not have been your converter making noise. Ouch. Cracked cylider as well. Well at least you will be able to fully use the Whipple after your rebuild.
Old Jul 30, 2005 | 09:30 AM
ICULOKN's Avatar
Damn that sucks... I guess your saying Whipple Woes because the power broke your motor? Or did something break on the Whipple and you think that made you drop a valve?
Old Jul 30, 2005 | 11:05 AM
tallimeca's Avatar
yeah
this shouldn't be called whipple whoes at all.
So you think there's still a problem with convertor.
Old Jul 30, 2005 | 12:04 PM
Tucsonpred's Avatar
There is a problem with the PI. It rattles like a kids toy. It shouldn't be called Whipple woes because this appears to have started before putting the Whipple on. Now the Whipple coulda taken out the PI but I think the valve might have explained the odd running cyl. The woe is more along the lines of unable to play with the Whipple.
Old Jul 30, 2005 | 12:28 PM
LatemodelRacer2's Avatar
harsh arent we the guy just lost a motor and a head but you jump on him over a title.
Old Jul 30, 2005 | 12:35 PM
35thPony's Avatar
I think whipple woes means he is sad cause no dynoing or whipple driving for a while..
Old Jul 30, 2005 | 02:32 PM
Casey02L's Avatar
Damn! Wasn't that a built motor?
Wasn't it on Sal's tune? I can't beleive the tune was bad; something must have went out on you like a fuel pump.
Old Jul 30, 2005 | 03:32 PM
brain bypass's Avatar
just jb weld it back together.
Old Jul 30, 2005 | 10:03 PM
l-menace's Avatar
well if you need someone to break in the whipple why you get that fixed, just let me know.
Old Jul 30, 2005 | 10:56 PM
LightninMike's Avatar
why would you blame a tune cause it droped a valve?
Old Jul 31, 2005 | 01:08 AM
Spanky99L's Avatar
Yes my block was already built. That was a manley piston.
Thde torque converter was maing noise. after i removed it you can shake it and hear everything on the inside. Pi said the clutches were toast.
Actually the truck was running great. My dad was driving it at the time and said it made a noise then shut off. What happened was the valve spring broke, kicked out the valve keepers and thus the valve entered the cyl.
The tune did not drop a valve. The issue was mechanical (broken modmax valve spring) and i in NO way blame sal or his tune for the motor.
Will
