Kenne Bell pulley
Old Jul 23, 2005 | 09:20 PM
dirtchicken's Avatar
Kenne Bell pulley
I dyno'd my truck today and I need more boost. How much boost would I gain from swapping the 3.5 to a 2.75? One more question, can you fit a JL 2.5 without grinding the snout down?
Old Jul 23, 2005 | 09:22 PM
2bscrewed's Avatar
Why not get a bigger crank pulley, so you have less slip problems.
Old Jul 23, 2005 | 09:38 PM
I already got an eight pounder on order.
Old Jul 23, 2005 | 10:10 PM
35thPony's Avatar
you'll gain roughly 6#
Old Jul 24, 2005 | 01:55 AM
2bscrewed's Avatar
If you have an 8# lower I don't think you'll want a 2.5 upper. I know a 10# lower with a 2.7 upper makes 22-24#'s on my friends built truck.
Old Jul 24, 2005 | 06:21 AM
My motor is also built.
Old Jul 24, 2005 | 08:39 PM
2bscrewed's Avatar
I figured you did, I was just saying I think you will be more efficient and have less problems if you keep the upper as large as possible, which means make your crank pulley as large as possible.
I've got a built longblock on the way and am trying to figure out what pulley combo to go with. I want to run 18#'s on the street and 20 at the track. I'm guessing if I run an 8# lower I can go between a 3" and a 3.25" upper to achieve this.
Old Jul 24, 2005 | 08:57 PM
meansvt00's Avatar
how much boost are you looking to run?
KB says with a
3.50 upper 9.0 lower(6lb) 13.5lb BOOST
3.25 upper 9.0 lower(6lb) 15.5lb BOOST
3.00 upper 9.0 lower(6lb) 18.0lb BOOST
2.75 upper 9.0 lower(6lb) 20.5lb BOOST
2.50 upper 9.0 lower(6lb) 22.0lb BOOST
if your gonna run and 8lb lower i would suggest running a 3" upper
Victor
Old Jul 25, 2005 | 04:25 PM
2bscrewed's Avatar
KB says with a
Victor
That chart goes out the window on ported heads and cams with full exhaust.
