Supercharger Flaking
Old Jul 23, 2005 | 01:58 AM
Big Shooter's Avatar
Question Supercharger Flaking
so i cleaned my intercooler today. i wasnt as hard as i thought. i just drove bout 15 miles to check it. i took it out for a quick run. it seemed alright, but its still doesnt feel as spunky as it did a couple weeks ago. i noticed that the coating on my supercharger rotors is flaking off. could this cause loss of power? is it bad? it still hits 10 psi but slowly. it used to get there quick. im gonna throw a JLP 4# pulley on it tomorrow and i wanna know if i should be concerned.
Old Jul 23, 2005 | 09:19 AM
evo's Avatar
evo
Check your adjustment on your Boost Actuator. It might have gotten out of spec when you pulled the blower.
Old Jul 23, 2005 | 09:57 AM
where can i find that thingamabob?
Old Jul 23, 2005 | 10:13 AM
SLVRLTNG's Avatar
here
about halfway down the page
Old Jul 23, 2005 | 10:30 AM
still kinda wondering if i should do something about my supercharger rotor coating flaking off.
Old Jul 23, 2005 | 10:39 AM
i forgot, it will still hit 10# it just doesnt jump there. i REALLY wanna throw this perdy JLP 4 pounder ive got sittin here on. should i hold off? i didnt mess with the Boost Actuator when i cleaned my I/C. i should still hold the stock setting. or could i have bumped it?
Old Jul 23, 2005 | 11:28 AM
Master Of Pain's Avatar
Don't worry about it. You can remove it with no ill effects. The coating helps with rotor heat management and is a filler to close some gap between the blades and the rotor case (as per a Manguson tech's explanation). At higher boost levels, it doesn't really matter anymore, as it's really only effective at 1-4 PSI.
Old Jul 23, 2005 | 11:47 AM
sweeeeeeeeeeeeeeet consider it installed
