hacking rear bump stops, how much??
Old Jul 10, 2005 | 05:44 PM
got hp's Avatar
Roush kit is in and I know the rear bump stops need to be shortened only question is how much to I hacksaw off?
Old Jul 10, 2005 | 06:14 PM
gbgary's Avatar
pictures sir, pictures!! i'd cut at least one section to start.
Old Jul 10, 2005 | 06:38 PM
Harley#356's Avatar
i swapped my stock rubber/foam bumpstops out for some energy suspension polyurethane bumpstops. bit stiffer than the stock ones and an inch shorter. then when i lowered it more i cut an inch off the energy suspension bumpstops. so depending how low you are, i'd cut at least an inch off, maybe even two. or just swap them out for a set of energy suspension ones for 10 bucks
Old Jul 10, 2005 | 06:41 PM
got hp's Avatar
got a part number for those energy suspension ones?
I'll post pics once it's clean
Thanks!
Old Jul 10, 2005 | 07:16 PM
Harley#356's Avatar
got a partnumber AND a pic!
http://fordtruckworld.tenmagazines.c...-4-album-19068
Stock vs Energy Suspension Bumpstops PN: 9.9101GC
you can see they are about an inch shorter than stock. with my 3" rear drop the energy suspension bumpstops were fine. when i dropped the rear another inch, i cut off the stepped part of the energy suspension bumpstop, just leaving the 1" cylinder part
Old Jul 10, 2005 | 07:26 PM
got hp's Avatar
awesome. Since I am leaving the back alone and not adding anymore drop to the Roush at the moment, I will order those.
Thanks a bunch!!
Old Jul 10, 2005 | 08:08 PM
Harley#356's Avatar
if there's a pepboys around you, they usually have them in stock. i think they were about 10 bucks
