One last question about the JDM e-fan
Old Jun 25, 2005 | 01:39 PM
John893's Avatar
I have completed the install but have two relays that came with the kit left over. The are in a FORD bag and the part number is F0AZ-14N089-A Are these just in case you don't have existing relays?
Thanks!!!
John
Old Jun 25, 2005 | 02:55 PM
SVT_KY's Avatar
Thanks!!!
John
I belive they go on the firewall ... that's where mine are.
Old Jun 25, 2005 | 10:31 PM
Robert Francis's Avatar
If JDM's e-fan kit is similar to LFP's e-fan kit - and they look alike - you need those relays as a part for the connecting wire harness supplied in the kits. As noted above - I mounted mine on the firwall.
Old Jun 26, 2005 | 10:14 AM
SonicLightning's Avatar
Thanks!!!
John
Remember that bracket you mounted? Well the two relays go inside it. The bracket would be difficult to mount with the relays in them. I know their directions are not very clear on this.
Old Jun 26, 2005 | 12:41 PM
John893's Avatar
Thank you very much guys, the relays belonged on the harness above the solenoid... What confused me is the fan worked when I turned it on using the switch.. .... but it would not work when turning on the AC or after driving it for 100+ miles yesterday in 90 degree heat. The truck never got hot, which is a good thing even without the fan running. Now the fan kicks on and off as it needs to and comes on as soon as I turn on the AC.
John
