Tie Rod Wear Help
Old Jun 24, 2005 | 03:34 PM
tallimeca's Avatar
Tie Rod Wear Help
As many of you know, Ford sent out a letter about tire rod inspections back a few months ago.
For the past month or so i've been getting a wicked knocking noise when i start and stock, or when going up and down my driveway.
I finally got under there to try and find out where the hell it's comming from
What i found is i can grab ahold of the tie rods on both side by hand and rotate the front and back. When they get to the point they stop, they make a knocking noise which is exactly what i'm hearing.
The boots aren't broken or cracked and there's no grease fitting anywhere to lube.
They don't exibit the characteristics of the verticle and horizontal play as described in the letter, but they are definetely making a noise.
I'm guessing they are junk.
Anyone know the part numbers to the inner and outter tie rod ends and approx price?
Old Jun 24, 2005 | 06:54 PM
LightninMike's Avatar
if its a recall have them do it. and what years did this affect cause i didnt get a letter for that just the CC one
Old Jun 24, 2005 | 08:29 PM
Herb101's Avatar
The letter I got indicates:
97-02 F-150
97-99 F-250
97-02 Expedition
98-02 Navigator
2002 Blackwood
There was a 4 step "Tie-Rod Inspection Procedure" on a single page along with a letter from ford. Let me know if you need it - I can scan it sometime this weekend and send it on over.
Herb
PS - Tallimca - check you U-joints too. Clunking when changing speeds or directions is often a sign of worn needles and caps in the U-joints.
Old Jun 24, 2005 | 09:38 PM
tallimeca's Avatar
yeah
i thought of that and my old man said that same thing but it's definetely commng from the front end and when i went under there and grabbed the tie rods, there's no question about it.
Once i change those, i can see what's making anymore noises.
Old Jun 25, 2005 | 09:01 AM
97-02 F-150
97-99 F-250
97-02 Expedition
98-02 Navigator
2002 Blackwood
Herb
yeah herb if you dont mind send me that. i am making a list of all recalls and work i need done and i hope to have them do it all at once
Old Jun 25, 2005 | 11:09 AM
afchad's Avatar
Damn....I didn't recieve a letter from Ford. Can someone send the info to me.
Old Jun 25, 2005 | 03:41 PM
usaf_eagle's Avatar
ditto.. im having a real bad knock.. i know i need clunk washers.. but im also getting a lot of little pops.. when the wheel is fully turned..
-Ronnie
Old Jun 25, 2005 | 03:53 PM
Herb101's Avatar
I've got to run some errands this afternoon and evening, but I'll sacn it tonight and post the link - I'll probably upload the files to LR or I may just post them here as .jpgs
Herb
Old Jun 25, 2005 | 07:59 PM
Herb101's Avatar
Here you go guys - let me know if you have any problems getting it.
http://www.lightningrodder.com/galle...up&cat=0&pos=0
Herb
ps - it's big for some reason
