Anyone have a pictorial on installing the western chassis front hangers?
Old Jun 23, 2005 | 11:27 AM
halflife's Avatar
Originally Posted by TXSVTLIGHTNING
Take the bumper off before the bed, other wise you will have to lift the bed up pretty high to get it over the bumper. 3-4 guys will do it. I recall when I removed mine to get repaired-
(4) nuts holding rear bumper to frame
Wire harness for lic. plate lights
Wire harness for tail lights on the frame (maybe a plug, seen some with and others with out)
(6) bolts in the bed
(3) screws around filler neck
you could use some sawhorses or an old table to set the bed on (so the ground effects pieces are hanging off the side and not touching the ground)
I also found my build sheet taped to the back of the cab once the bed was off (but my truck was only a few weeks old still)
thanks
