Digital volt meter
Old Jun 15, 2005 | 01:27 PM
LatemodelRacer2's Avatar
Digital volt meter
I was wondering if there was somewhere i could find a digital voltmeter like just the display so i could mold it into my gauge pillar to watch my mass air voltage.
Old Jun 15, 2005 | 01:56 PM
WaveBlaster785's Avatar
Cool idea.
Check out discounted places like Harbor Freight.
Old Jun 15, 2005 | 02:14 PM
Harley#356's Avatar
could you use a normal volts gauge? and just wire it into the MAF rather than where it normally attaches?
Old Jun 15, 2005 | 08:27 PM
I currently have a wire running from the mass air to under my floor mat. When i want to watch mass air votlage i hook my digi volt meter to it and let my buddy watch it. I just would like to have the little display mounted in the pod to where it looked proffesional and still functioned all the time instead of hooking it up.
Old Jun 15, 2005 | 09:05 PM
BDAZSVT's Avatar
Radio shack??Build your own. What about an autometer voltmeter?
Old Jun 16, 2005 | 12:11 AM
I wonder if radio shack will have the display by itself?
Old Jun 16, 2005 | 03:38 AM
Unoid's Avatar
Buy a cheaper volt-meter (not a fluke ) and jsut dism antle it and mount the display how you want and hardwire the power of the device to your battery and hardwire the leads to the maf voltages. Not too hard.
Old Jun 16, 2005 | 07:21 AM
jarmstro's Avatar
Try here....
http://www.gadgetseller.com/gauges/index.htm
Old Jun 16, 2005 | 08:44 AM
brain bypass's Avatar
i just use my predator. i don't think maf voltage is really something that you need to keep an eye on. check it on a nice cold day, and see what it peaks at. why would you need to watch it constantly? it is not like it will all of a sudden peg.
Old Jun 16, 2005 | 11:32 AM
Mine currently is running 4.90-4.92 the last few times i checked it and that was in the heat of the day so i think im at the point where i need to watch it untill i can afford a sct mass air.
I emailed gadgetseller about it untill then i might look into unoid's idea.
Old Jun 16, 2005 | 01:27 PM
typhoon43's Avatar
You can try Dakotadigital.com Not sure if they register under 10 volts though. I've had a few for my stereo setups.
Old Jun 16, 2005 | 01:52 PM
http://www.dakotadigital.com/index.c...rod/prd358.htm
range 0-17.0 volts in 0.1 increments
i amd getting dd temp gauges because they register down to 0*F
Old Jun 16, 2005 | 01:56 PM
Looks good brian. ill probley get that since i have a steering column pod that im not using anymore that i could put back on for this to go in.
Old Jun 16, 2005 | 01:59 PM
my screen name is BRAIN, as in the noodle on your head.
you could put a switch on it, and make it a voltmeter as well, as we don't have a battery gauge.
-glenn
Old Jun 16, 2005 | 03:28 PM
the only problem with that gauge though, is it reads in 0.1v increments. so, unless it hit 5v, you wouldn't know if it was 4.90 or 4.94, or if i didn't round up, 4.99v
you might call or email dakota digtal, for more details, they will give a quick response, but i think you should probably keep looking.
