Did someone say 32 Valves???
Old Jun 14, 2005 | 07:11 PM
  #31
Suavy's Avatar
What intake are you rrunning? Can you give us some info on your intake set up?
Peace,
Suavy
Old Jun 14, 2005 | 08:03 PM
  #32
Bad as L's Avatar
Originally Posted by LightningTuner
Honestly I would reconsider the D1SC. It's a great head unit, but I don't think it's going to support the kind of power you are after. I would suggest something larger, like an F1R or D2. I ran the F1R on my Lightning. I made 705 rwhp with it, on a race tune. That was at 22 psi. I really don't think the D1SC will made the power you want, even with the 4V heads. Just my 2 cents.
Also, you're not going to like this if you haven't done it already, but you ABSOLUTELY MUST double key the crank. The modular crank snout is very small, and the keyway design is very poor. I started to roll the keyway out of the crank under the load of the Whipple, and the Procharger just ripped the whole balancer and pulley off. You need to double key the crank, and use an ARP crank bolt.
Hope this helps. I've been down this road already.
Very good advice and I might add...you can re-drill/tap the nose of the crank for a larger ARP bolt.....maybe bump it up to 5/8" ....I would anyway.
Dale
Old Jun 15, 2005 | 02:10 AM
  #33
ScrewOnBudnik20's Avatar
Sal, I hear what your saying about the key way and understand 100 percent. I personaly think after following your build up closely with Derek that the reason the keyway sheared was more than likely the added stress of the cog setup along with the F1's 5 to 1 step up ratio. I also think that the F1 was robbing a considerable amount of HP just to turn it, but without a side by side no one will know. The cog setup has got to be a heck of a lot harder on the crank than just a 6 rib belt that can slip when it needs to. But if and when mine does break I know what will go in in its place.
Old Jun 15, 2005 | 02:12 AM
  #34
The intake is a sullivan intake that I am going to cut a butcher very soon. I'm going to cut the water crossover off and weld in an fittings in its place, and run a evans remote thermostat.
Old Jun 15, 2005 | 10:03 AM
  #35
LightningTuner's Avatar
Actually cogs are easier on the drive components, because cog belts aren't run anywhere near as tight as ribbed belts.
Old Jun 15, 2005 | 10:16 AM
  #36
larryp's Avatar
Pure art. Simply beautiful.
Good luck.
Larry
Old Jun 15, 2005 | 12:14 PM
  #37
well photobucket sucks now who do I use to put up pictures for free
Old Jun 15, 2005 | 12:19 PM
  #38
brahmus's Avatar
why not the galleries here?
Old Jun 15, 2005 | 12:32 PM
  #39
Old Jun 15, 2005 | 12:54 PM
  #40
l-menace's Avatar
you can use.
www.motorcityoutlaws.com
and host for free with unlimited bandwidth
Old Jun 15, 2005 | 04:01 PM
  #41
Rob_02Lightning's Avatar
Smoooooooooooooooking ScrewOnBudnik20
Old Jun 15, 2005 | 04:16 PM
  #42
Whitetrash SVT's Avatar
Last edited by Whitetrash SVT; Jun 15, 2005 at 04:17 PM. Reason: Wrong Name........
Old Jun 15, 2005 | 04:18 PM
  #43
SVT F15O's Avatar
Looks like a NASTY setup.
I am going to have to agree with Sal though. Double key the crank! You are gonna be very mad at yourself when you have to pull it back out and apart over a broken key way. -Mat-
Old Jun 15, 2005 | 06:09 PM
  #44
owheelies's Avatar
Are you doing that so the alternator can mount up top?
Looks good BTW.
Eric
Old Jun 16, 2005 | 04:41 AM
  #45
Yes so the alt can go in stock location.
