looing at buying a wideband
looking at buying a wideband
i was looking at a few different models. the fjo is nice, but expensive. the dynojet model is nice, but i want one that has a digital gauge i can put in my gauge pod. the purpose is to keep an eye on my a/f while driving, so more of a warning system than a tuning device. although i should be able to datalog the a/f on these for sal to dial in my tune.
any thoughts, comments, experiences with any of these?
i was looking at the following units:
innovate:
http://www.innovatemotorsports.com/...=252&page=1
plx: (either the 250 or the 300, but with the add on 2 1/16" gauge)
http://www.plxdevices.com/M-Series_productinfo.htm
aem:
http://www.aempower.com/product_ems.asp
innovate:
aem:
I have the Innovate set-up, but I have the LM-1, LMA-3 and the XD-1 gauge as I bought them as they came out with them. If you are really just wanting a gauge, get the XD-1 with the LC-1 for $399. It has 2 programmable outputs if you want to feed it to something like a laptop or the XCal2 for datalogging.
Didn't know if you were aware of this or not but the dynojet gauge has a red warning light on it that you can program the box for when you want it to alert you...i.e say if your at 12.2 above 3K the red light comes on...kind of cool...
Originally Posted by brain bypass
didn't know about that, but i just don't like the analog gauge. i wish it had the option of a digital gauge, then i would buy it in a second.
It also has a programmable analog output for external datalogging. You could make a digital readout that gets its value for display from this analog out. It may take a bit of circuit design, but that stuff is cool anyway! What is the cost difference your seeing between the digital models and the DJWBC? If its fairly close, it would likely not be worth the hassle, but for enough bills saved, it may be worth looking at.
Herb
the wbc is more. i might be able to find it for close to the innovate unit, but i am not positive on that. why not spend less money for what i really want?
I have not prices the other units, so I did not know how they compare against the WBC. The WBC has worked well for me, but I actually wanted the analog readout and was not wanting to deal with a single digital gauge in a sea on needles
.All of the units seem to perform well, from what I have heard. I only have experience with the DJ model.
Herb
BTW - on the HALO site, Phil posted some good links to some 'training' videos from LM-1. Might be worth your while to check that out - it's a bout a week old post by now.
Tech Edge (wbo2.com) has the most accurate wideband O2 meters. They use a 12 bit DAC as opposed to a 10 bit DAC which results in a 4 times greater accuracy. The LM-1 is also a good unit, but 10 bit. The Tech Edge basic 2A0 unit logs RPM 3 0-5 volt sensors (like throttle position, etc) and 3 thermisistor inputs(EGT) built into the hardware without having to purchase additional items. They also have a DIY kit for those of you that are good with a small soldering iron.
to bad they are in australia, although the diy kit is tempting. the assembled kit is too expnsive.
the innovate lm-1 is 10-bit
the innovate lc-1 is 12 bit
