e fan stuck on... dangit!
Old May 30, 2005 | 01:04 PM
AMP's Avatar
AMP
Question e fan stuck on... dangit!
just started doing this after 1 year of working properly. always on when the truck is running whether hot or cold. It's a JLP setup. wondering if it's the sending unit stuck on, or if it could be a bad relay. Also, there's a little silver electrical component under the relays that I don't know what it is.
Any ideas?
Bueler, anyone, Bueler??
Old May 30, 2005 | 01:51 PM
tallimeca's Avatar
check it out
undo the sensor wire and see if it stays on. Simple. Eiter that or just put a continuity tester on the sensor and see if it's grounding all the time. If it is, then the sensor is no good. If it's not , then your know the relay is sticking.
Good luck.
Old May 30, 2005 | 04:06 PM
AMP's Avatar
AMP
Good idea, thanks. I'm going in.
please don't be the sender
please don't be the sender...
Old May 30, 2005 | 04:53 PM
l-menace's Avatar
the temp senders are cheap!
Old May 30, 2005 | 05:03 PM
AMP's Avatar
AMP
It's the antifreeze bath that I don't enjoy!
Old May 31, 2005 | 06:59 AM
KB ZILLA's Avatar
I heard my sensor "crack" when I installed my built motor last year....I kept my fingers crossed hopefully it was okay...but the fan stayed on all the time ....and I had to take the "antifreeze bath"...I feel your pain
