Tire Wear Help
Old May 28, 2005 | 01:22 PM
l-menace's Avatar
WITHOUT the clunk washer installed, do you think that could contribute to the front tires wandering when it hits bumps driving down the road and following the "divits" in the street
Old May 28, 2005 | 07:14 PM
gbgary's Avatar
Originally Posted by SILVERLIGHTNING
You should install "Clunk Washers" to help keep everything within specs.
Without them the driver's side lower control arm may "wander".
FF
i finally got my alignment/clunk-washer install done today at the local dealership...$89, all is well. noise gone, no pulling, tires saved!! got my washers from his guy i think (it's been a while) dplynn1@bellsouth.net
Old May 29, 2005 | 11:40 AM
SILVERLIGHTNING's Avatar
That sounds like the typical F-1 experience.
Without the clunk washers the alignment will change, so it MAY contribute to the front tires wanting to pull the steering wheel out of your hands, but I think it is mostly the tires.
FF
Old May 30, 2005 | 09:45 PM
sostenon250's Avatar
So to make sure that I don't go through this tire alignment nightmare again, it sounds like I need to invest in some clunk washers ?
Who would be the choice to order from, PSP, JDM, Mike T, LFP, Chick?
Also, I've seen the diagrams for install but how long does it take and is a lift required ?
