Messed Up ?
Old May 14, 2005 | 04:35 PM
Jason Rawls's Avatar
Messed Up ?
Have an 03 Lightning. Stock it had 343RWHP / 414 Lbft.
I added a JLP CAI, 6lb Pulley, Predator Tuned.
Now it is 381RWHP / 497 Lbft.
But, my friend said that he heard it pinging.
And now it seems like it is tapping ........ =(
Does it sound like the damage is done ?
The air fule was 12.1 to around 11.8 throughout the pull.
The dynoshop addded 8% fuel with the preadator.
With this set up do I need to run a colder plug (iridiums ?) ?
The kit came with a 180 deg. thermostat that I haven't installed yet.
Any info is much appreciated.
Old May 14, 2005 | 04:54 PM
FunFord's Avatar
Registered User
Pinging could cause serious damage if not taken care of right away, let your tuner take a look at it. Tapping is probabbly piston slap whitch is very common with 5.4L Ford engines.
Old May 14, 2005 | 05:06 PM
Well I was seeing 15 PSI when I was on the dyno on a bone stock L (except for the CAI, Pulley, and tune)
Old May 14, 2005 | 06:00 PM
Silver-Bolt's Avatar
What is you timing? Pull the plugs and look at them. They will be a good place to start looking for damage.
Old May 14, 2005 | 08:32 PM
OH-MAN's Avatar
Pinging very very bad.
Looking at the plugs is a great way to see if anything real bad happened.
Old May 22, 2005 | 10:15 AM
O.k. ...plugs are fine ....
Still can't re-create the "pinging" ......(good thing)
Could it have been a dose of bad gas?
Now that I am all paranoid (still under warranty)
It does sound like valves are tapping at idle.
I can't hear it unless I pop the hood.
Isthis common for the L's ?
Old May 22, 2005 | 10:16 AM
Oh, I did put 2 gallons of race fuel to 10 gallons of 93 oct .....
Old May 22, 2005 | 10:25 AM
2000L's Avatar
If you can only here it with the hood popped, its probably just your fuel injectors. The tend to be a bit noisey and make some what of a similar noise to valves tapping.
Old May 22, 2005 | 10:28 AM
Rob_02Lightning's Avatar
Is this common for the L's ?
Yes bad gas can DEF cause Detonation
As said Detonation IS REAL BAD
I doubt very much your hearing tapping from the valves
If you open a L hood and listen real good
YOU'LL HEAR ALL KIND OF WEIRD NOISES
schitt'll drive you crazy I tell ya
Injectors make a ticking noise many associate as drivetrain noise.
Piston slap is common for a L and sucks, but not the end of the world.
YES WITH 6LBS OF PULLEY YOU NEED COLDER PLUGS THAN STOCK
(Btw, that will also help PREVENT detonation )
And if I'm correct, you DO NOT want a 180 Therm, you want a 160'
Old May 22, 2005 | 10:37 AM
Odin's Wrath's Avatar
The 160* thermostat and colder plugs are good things to take care of. They can make a difference.
