QA1 Rear mounting brackets
Old May 12, 2005 | 07:53 PM
chief40al's Avatar
Question QA1 Rear mounting brackets
Today I installed my QA1 rear shocks.
I am not happy with the way that they fit in the upper brackets. What has every one else done for the top brackets.
Too much play in the holes.
Old May 12, 2005 | 08:04 PM
blown318's Avatar
Re: QA1 Rear mounting brackets
Thats what she said!!!!!!!!!!
Old May 12, 2005 | 08:09 PM
chief40al's Avatar
Re: Re: QA1 Rear mounting brackets
Sounds like a personal problem
Old May 12, 2005 | 08:23 PM
OH-MAN's Avatar
I think Stan Ruslow has a heim kit to convert them.
Old May 12, 2005 | 08:39 PM
camcojb's Avatar
I also don't like the way they fit, plus the lower bushing is too narrow and requires a couple of washers to fit correctly. I called QA1 and they said to use the stock upper bushing, but then their stud is way too short to get the nut started. I ended up shaving the stock upper bushing enough to get the nut started and tightened, and shimmed the lower mount. Disappointing since they list it as a direct replacement. Oh well, wadda ya want for $275.!
Jody
Old May 12, 2005 | 08:55 PM
Casey02L's Avatar
Jody
That's what I ended up doing with mine exactlly.
Old May 12, 2005 | 10:04 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Ruslow heim joints will solve your dilema.
Old May 12, 2005 | 11:55 PM
mike00L's Avatar
Al,
call JDM and ask shaun what he uses. He just did mine the other day and they add there own piece to it to make it fit right. Dont ask me what it is though
