Toluene!!!
Old May 9, 2005 | 03:54 PM
PittsburghSvt's Avatar
Toluene!!!
I just called and it seems like i can get a 55 gallon drum for 273.00... just under 5 bucks a gallon.. what kind of prices is everybody else seeing.. and how safe/effective is it..
Old May 9, 2005 | 04:30 PM
lightningkylej's Avatar
I paid about $4 a gallon in OK City. I only used a gallon in a full tank once. I made starting my truck a little weird, like it was flooded. I still have the second gallon in the garage. I know other guys here that have used it and with no problems that I'm aware of. I suggest trying it before spending that much money on a drum of the stuff.
Old May 9, 2005 | 04:38 PM
smokingozzy's Avatar
I use it a couple of times a year when I can't get racing gas! I've never had any problems!!! Jim
Old May 9, 2005 | 04:57 PM
thats what i was planning on doing.. buying a gallon, trying it, then buying a 55 gal, if i like the results...
Old May 9, 2005 | 05:11 PM
GRAYONE's Avatar
Wink
For what its worth. Xlyene works well to. Just make sure to put a few drops of marvel mystery oil in the mix for lube.
Old May 9, 2005 | 05:12 PM
what is marvel mystery oil?????? and what exactly is xylene????
Old May 9, 2005 | 05:24 PM
LightninMike's Avatar
its a mystery but really you can find it in just about any parts store
Silver-Bolt's Avatar
Watch your ratios and you will be fine. When you start exceding about 30% it can be hard on rubber parts.
Old May 9, 2005 | 05:27 PM
i would start out with 1 gallon in a full tank, and then go to 2 gallons in a full tank, and see how she runs.. is the mystery oil for lubercating parts because the toluene is a solvent and might wash the cylinders or something???
Old May 9, 2005 | 05:56 PM
CaptainInsane-O's Avatar
Here's a good thread from a while back discussing the in's & out's of Toluene & Xylene homebrew
https://www.f150online.com/forums/sh...hreadid=157558
Doug C.
Old May 9, 2005 | 06:17 PM
ok... starting to make alittle more sense.. without a tune, would i benefit any from rasing the octante a few points, maybe like a 10-20 percent mixture...
Old May 9, 2005 | 07:54 PM
SVT_KY's Avatar
I have run 40-50 percent Tolulene for years
and the only result was nice CLEAN plugs ... < grin >
Cliff
5 gallons to a 1/4 tank is my ratio ...
Cost ... about 38 at Sherwin Williams
Old May 9, 2005 | 08:50 PM
Cliff
is that all the time or only at the track??
Old May 9, 2005 | 09:58 PM
SVT_KY's Avatar
Track only !!! On a great tune for 105 Octane by PSP !!!
Old May 9, 2005 | 11:26 PM
l-menace's Avatar
YOU MUST ADD MARVEL MYSTERY OIL! Just a little.
I run a gallon through my vehicles one a year to clean everything out. ASMOF, I need to run it through the Lightning to clean it out.
