Pillar Gauge Pod Question
Old May 7, 2005 | 02:39 AM
NorCalLightning's Avatar
Question Pillar Gauge Pod Question
Which ones fit the 2004's?
I bought an Autometer dual pillar pod setup (part# 17310) and I don't think it's going to fit properly. I did a test fit under the "oh *****" handle and it appears to not even come close to fitting right. The bottom pod is smashed against the dash and the upper part of the pod setup does not fit over the stock pillar very well (has to be bent to hell to get it to even come close to fitting).
Do I have to use a heat gun to persuade it to fit? Its appears this may help in getting the top to fit the stock pillar. As far as the bottom gauge pod hitting the dash, I think I'm stuck with that.
Post some pics of your dual pillar pod setups, especially if you have an '04.
Steve
Old May 7, 2005 | 06:36 AM
wjm5806's Avatar
Did you get the half pod or the whole length pod? I have the whole length and had to trim the top to make it fit.
Old May 7, 2005 | 12:44 PM
It's the partial one. It goes under the handle.
Steve
