pully and nitrous
Old May 5, 2005 | 01:40 AM
Lightning1983's Avatar
pully and nitrous
i put a 75 dry shot with NGK's on my lighting and i have a 4 lb pulley with the predator tuner that i havent put on yet i know ill be taking a chance by putting it on but is there anyone else on here that runs anything like that with a stock truck?
Old May 5, 2005 | 06:09 AM
cpeapea's Avatar
probably best to run a wet shot, and make sure you get the thing dyno tuned.
Old May 5, 2005 | 07:01 AM
Rob_02Lightning's Avatar
WELCOME TO F-150 1983
I've been spraying dam near 3 years now on my Lightning.
Orig set up on the stock Motor was:
4lb Lower, 2lb Upper, Ported Eaton, Cool Air Induction, Accu Fab Throttle Body, and 75- 100HP of WET Nitrous. Motor was still running perfect when we built it this winter, "however" there were signs it was near it's death, our timing was perfect.
It is NOT GOOD to run a dry shot on our Lightnings,
way too much to go into here, but the bottom line is anytime you have a Turbo or Supercharger, you ALWAYS want to run a wet kit.
Ok but you have a dry kit, so lets talk about that, and yes many have ran it on a L before. Some blew it up, (our F-150 Brother Chim Shady for example) some got away with it a while, most switched to Wet Kits or just stop using it all together. 98-99% that Spay a L, DEF spray Wet
My opinion would be, DO NOT under any circumstance's Spray it till you get yourself a very Rich NITROUS Tune, you want all the fuel you can get in that Motor especially since your relying on the n20 system to send a signal to add more fuel. This may call for the Bigger Fuel Pumps as a safety precaution. This may call for bigger injectors to assure the extra fuel is going in, thats where the extra fuel is going to be put in, (not a seperate source and place like a Wet Kit). This DEF calls for colder plugs, I would go with BR-7's. And due to the fact it's a dry kit, I would not spray more than 50-75 HP EVER, and I would keep the timing @14-16 Degrees the most, you should start with even less.
You must understand that a Wet System shoots Raw Fuel in the Motor along with the Nitrous, (both at the Nozzle) so you are not depending on your Injectors or any signals from the System to tell the L Computer "hey we need fuel, and A LOT of it". AND HERE'S WHERE THE PROBLEM LIES
A stock L fuel system is marginal at that, and we all NOW know a Lightning motor is a Steel I Beam that can turn into a Sheet of Thin Glass "in a mili-second under a lean condition".
At least with a Wet System, you are not relying on Both Systems to talk to each other and send signals to the L Computer to send Fuel to the Injectors. Another words "we dont have that time", it could be to late .
I dont want to scare you, I dont want to say dont use it, I just want you to realize the difference between the two systems and know their limits and short comings. For this reason I would keep the shot to a minimum, have a very rich program, get as much heat out of it as possible, and have fun
CONGRATS, AND ENJOY THE NEW FOUND POWER
Old May 5, 2005 | 09:31 AM
Bootbox's Avatar
If you run a stock Predator (not custom for your application) pulley tune with a 4 pounder and a 75 dry shot, you're on very borrowed time before you window the block.
I wouldn't do it without a custom dyno (not mail order) Predator tune.
Old May 5, 2005 | 10:09 AM
03WHITELIGHTNIN's Avatar
Also make sure you have race gas.
Old May 5, 2005 | 10:12 AM
LatemodelRacer2's Avatar
get yourself a nitrous tune. there are many pulley/nitrous L's out there but all have a good rich nitrous tune and a wet kit
Old May 5, 2005 | 11:41 AM
Yeah maybe i'll just hold off on the pulley for now and just run the shot
Old May 5, 2005 | 11:59 AM
RustySocket's Avatar
You'd be better off ditching the juice and putting the pulley on it if your not gonna get a dyno tune. Way cheaper in the long run.
Old May 5, 2005 | 12:09 PM
Yeah i would but i already got the juice hooked up ive sprayed it like 8 times its not detonating or anything its taking it fine i also got the 160 degree thermostat not sure if that will help or not tho
Old May 5, 2005 | 12:51 PM
aslong as its not detonating it should be alright right? or am i wrong? i mean its not mounted close to the throttle body its mounted back before the mass air so im probaly not getting the full affect its mounted through the top of the filter box
Old May 5, 2005 | 01:17 PM
Re-read Robs post.....
Old May 5, 2005 | 02:24 PM
HANKFAN's Avatar
I ran a 75hp dry kit on my truck for about a year with no problems. However, that was before my ported blower and 4# lower. I currently run a 75hp NX wet shot with a ported blower and a 4# lower. I know I am at the limits of the stock block but so far so good!!!!!!!!!
Old May 5, 2005 | 02:31 PM
HANKFAN's Avatar
-edit-
Old May 5, 2005 | 03:56 PM
its a nice looking truck man
Old May 5, 2005 | 05:10 PM
svtguy12's Avatar
Every bolt-on, 4lb'er + a 100shot of progressive from RaceTested.com.
I've used it with about twenty hours of dyno time for just the nitrous side of thingsand it's safe & just awsome.
