Oil pressure Sensor Q?
Old Apr 24, 2005 | 07:41 PM
Whitelighting's Avatar
What do i need to relocate the sensor,wanna tee off factory sensor and maybe run line from the tee to another location ,why you ask the electic gauge sensor is huge scared it might work its way loose.Its a auto meter electric oil pressure gauge.
Thanks all for any info..
Bob
Old Apr 24, 2005 | 08:06 PM
01 XLT Sport's Avatar
I have mine installed with a brass cross fitting. It goes into the block, where the factory oil pressure sender was located and on the cross I have the factory oil pressure sender, the Autometer oil pressure sender and Autometer oil temperature sender.
No problems, just use Teflon tape and make sure your brass fittings are snug. It isn’t going anywhere…
Old Apr 24, 2005 | 08:09 PM
Thanks.
Bob
Old Apr 24, 2005 | 09:18 PM
SLVRLTNG's Avatar
look here, works fine:
https://www.f150online.com/forums/sh...threadid=84014
Old Apr 24, 2005 | 09:24 PM
That’s what I did except I used a cross to install the OEM oil pressure sender, Autometer oil pressure sender and Autometer oil temperature sender:
Old Apr 24, 2005 | 10:52 PM
Thank you again looks great i will take the sensor with me to get the right fit.
Bob
