Battery Light Q
Old Apr 9, 2005 | 02:38 AM
Derek94's Avatar
Battery Light Q
Hellooooo everybody,
Got in my truck tonight, drove for about 5 minutes, and then the battery light came on, and my lights dimmed down. Pulled the predator out, voltage was 11.5 or 11.6, and maintained that way till i got home. The battery and alternator are stock, 68,000 miles. 2001 Lightning. Which do you think is the culprit? Truck has always started easily, i thought the gauges would sweep if the battery was getting weak. Well thanks
Old Apr 9, 2005 | 07:55 AM
StruckBy99's Avatar
If your battery was comletely dead, the gauges would sweep the next time you turned the key with a charged battery.
Sounds like your alternator is bad. A volt meter on a running truck should show around 14volts. 12volts or less means the truck is running off of the battery and the alternator is not charging.
Hope this helps,
Jason
