IAT1, IAT2 vs Timing retard
At what discharge temps does the PCM pull timing and how much?
I've noticed that since I've added my 2.8 to my 4# lower that it seems to make no difference weather I run my 16* or my 18* tune. It still only run high 107mph.
With the 4# lower I was allways high108 or low 109mph even on slicks.
Is my PCM pulling timing or is it simply to hot of discharge temps to make a difference?
IAT2 temps can get well over 145 in the TOP of third gear. I've seen 150* in third gear @ 115+mph.
What should I do? The truck is mainly a track truck but I do use it for cruising also when the weather is nice. Should I add a supercooler? or a Ported blower?
A ported blower would put me close to beaking point of a stock block right?
A supercooler would take advantage of the current boost by cooling the dischage temps right?
Here is my current mods: 4#lower, 2.8upper, JL cold air, Denso plugs, 100mm idlers, Monster Box TD convertor, JL traction bars, JL saftey loop, JL dyno tuned Pred..404/508 with out the 2.8upper.
Sounds like your heating the charge up right much. I think that w/ ur current combo, plus an apten or whoever you use, your temps will drop significantly. Larger heat exchanger may also be in the works. I run an Apten and a 4lb, 14-16psi dependant on weather, and my temps dont reach that high. If you ported, you'll be adding boost no doubt, but its a much cooler air. I think back in the day they were posting results of the apten, and an apten w/ a 4lb was cooler than a stock unported eaton @ stock boost. Correct me if im wrong guys, i THINK i read that.
Re: IAT1, IAT2 vs Timing retard
Just out of curiosity, was your tune adjusted for the additional 2.5 psi of boost?? I run non-ported Eaton with a 6# lower and stock upper with 21 degrees of timing, other mods are similar, and run 109-110mph in the 1/4.
Jason
Jason
