Trailers for Lightning
Old Apr 7, 2005 | 04:41 PM
chief40al's Avatar
I am looking for some recomendations on an open type trailer.
No she will not be a TRAILER QUEEN all the time.
Just for the long runs,Fla.Ga,Va,NH etc.
Thanks for the input
Old Apr 7, 2005 | 06:24 PM
Casey02L's Avatar
Just be sure you check the width; I got a 75" one and it WOULD NOT fit. I think an 80" wide would be ok, but close.
Old Apr 7, 2005 | 06:25 PM
nightmoves's Avatar
Check with Hecht trailer in Toms River.They might not be the cheapest but they have a huge selection in stock.
Old Apr 8, 2005 | 12:18 AM
VINNIE's Avatar
Al,
My suggestion is to look for an aluminum trailer if possible. Our Ls weigh a lot and then theres the extras (Jack, Slicks,fans, generators,etc..) that your new F-150 will be towing about 5300-5400 lbs w/o the trailer.
I know they are more expensive , but they also keep there value very well.
You should definately go to the E-town swap meet (April 15,16,17) as there is always open trailers with "Show" specials.
VINNIE
Old Apr 8, 2005 | 01:59 AM
03LightninRocks's Avatar
Mine is a 80" x 18 foot dovetail. It has the electric brakes on both axles(I had it only on one last year and the brakes would get hot as hell in mountainous terrain). It has wood decking and two ramps, that I welded an extra 2 foot on each to make the ramps longer to keep from scraping the front of my truck.
Get a load leveling hitch.
I have roughly 1700.00 in the trailer with the extra brakes I put on it.
load level hitch ran about 400(maybe)
The trailer weighs in at 1800 lbs unloaded. This would be the minimum set up I would recommend.
If I had it to do over,I would do aluminum(as Vinney Recommended) and get the 7500 lbs axles.
OH...and with 80" wide I have about 2-3 inches on each side of my Lightning. I usually don't miss the center ....any more...LOL.
Old Apr 8, 2005 | 07:50 AM
chief40al's Avatar
Vinnie
What brand is yours ?
Old Apr 8, 2005 | 08:02 AM
SMOKINTRUCK#1's Avatar
Featherlight trailers are top notch trailers they have all shapes and sizes! Also easyhaul check them on line. Goodluck!
Old Apr 8, 2005 | 11:47 AM
VINNIE's Avatar
Originally posted by chief40al
Vinnie
http://www.worthingtontrailers.com/t...ail.aspx?ID=24
Old Apr 8, 2005 | 12:35 PM
PhillipSVT's Avatar
if you can get a trailer with torsion axles, they are awesome. Would take the bumps well and not jar the truck as much.
