blower oil leak
Old Apr 5, 2005 | 10:28 PM
NATAS's Avatar
blower oil leak
here's a good one. i just realized my new magnum powers is leaking from the snout right behind the pulley. it's only looking to be a little bit at this point. i don't know if when i installed it i put too much oil in it or what. i followed the instructions as far as filling to the bottom lip of the fill hole.
if anybody knows of this problem let me know what to do or what to expect.
like i said i filled it to recomended capacity(is there a vent at the end of the snout?) and the only other thing is that i put on a intake spacer w/ stock length belt (maybe too much tension?)
thanks
Old Apr 5, 2005 | 10:32 PM
l-menace's Avatar
Is it a new one? I thought I read they redesigned the face of the casing to fix the leaking.
Old Apr 5, 2005 | 10:42 PM
NATAS's Avatar
i suppose it's new i just installed it about three weeks ago and bought it from jdm about a month ago, maybe old stock, i hope not or the sh*t is gonna hit the fan
Old Apr 5, 2005 | 10:44 PM
Rob_02Lightning's Avatar
Originally posted by Magnum Powers
I have received a few, 5 or so, Magnum nose assemblies back for “leaking” that I warranted. I just got one a few days ago and the lip of the seal was ripped up around ¼ of its circumference because the lip was rubbing against the bearing race. I have since switched to a seal that I have used for years in another supercharger that is made such that there is a space between the lip and the bearing race so this failure mechanism has been eliminated. If you guys know of Magnum owners who have leaking nose assemblies and want them fixed have them the send me an email at: charles_warner@mindspring.com and I will take care of them.
Charles
Old Apr 5, 2005 | 10:49 PM
Magnum Powers's Avatar
Please give me a call Natas and I'll take care of you pronto.
My phone # is: 503 357 5444 or send me an email: charles_warner@mindspring.com.
Thanks,
Charles
l-menace's Avatar
SOLVED...
Old Apr 5, 2005 | 10:58 PM
NATAS's Avatar
Thanks,
Charles
thank you very much for the quick reply
i will give you a buzz tommorrow. again thanks
Old Apr 5, 2005 | 11:06 PM
NATAS's Avatar
rob 02 and i-menace thanks for the help as well. it's nice to know i can look to guys such as yourselves for knowledgeable info and advice.
cheers
Old Apr 5, 2005 | 11:30 PM
No Prob Bro
I was just hanging out anyway
Old Apr 5, 2005 | 11:51 PM
Scott Dunn's Avatar
Mine leaks also! from the snout and from the case. I still havent acheved 20+ PSI of boost with a 10# lower pulley!! Ive seen 19 once with the 10#
I should have just bought the Kenny Bell!!!!
Scott
Old Apr 5, 2005 | 11:56 PM
Suavy's Avatar
also remember that to much belt tension can cause a seal to fail also.
Scott, Ask Don's bolt about Kennt Bell.
Suavy
