Air? Check. Spark? Check. Fuel? Negatory. Truck won't start.
Old Apr 4, 2005 | 01:54 AM
MISTERgadget's Avatar
Originally posted by Casey02L
Mine did the same thing to me a while back; I searched and searched. Still not sure what happened to it just like you said; it went back to starting.....
Did yours do the same thing with the gauges?
Maybe it'll go away tomomrow morning and never happen again or something? I hope it's one of those gremlins. :o
Old Apr 4, 2005 | 02:22 AM
LightninMike's Avatar
my guages craped out on me when my alt craped the bed but you would know that cause the truck wouldnt start after that
i would check all relays anad fuses again
cause if you cant hear the pumps coming on they got no power
Old Apr 4, 2005 | 10:20 AM
Whitetrash SVT's Avatar
Originally posted by MISTERgadget
edit: NONE of the gauges do anything until about 5-10 seconds after it starts. Cluster on it's way out?
Do they do a full sweep or just do nothing?
If they donothing then do a full sweep each time you start it maybe the chip went bad or you have a power/ground issue w/ PCM causing it to lose memory.
Old Apr 4, 2005 | 12:33 PM
Casey02L's Avatar
I am pretty sure the guages were fine with mine. It was very strange; I did like you going threw EVERYTHING. I even replaced the fuel pumps(which I was planning to upgrade anyway) Was just trying different things; did a few key cycles and mine went to working again and has been fine ever since.
