Driveshaft breakage
Old Mar 30, 2005 | 09:28 PM
bglanden's Avatar
Driveshaft breakage
Where do our driveshaft's typically break?? Reason I'm asking is, I made a driveshaft loop and it bolts up close to the front universal joint. If typical breakage occures after the first tube weld then the loop is basically useless.
I searched on here and it seems most of the Vendors make them to attach near that weld, mine is close to the weld.
Thanks in advance,
Bryan
Old Mar 31, 2005 | 04:07 AM
Red03SVT's Avatar
I'm pretty sure it'd break at the weld and/or an area with the smallest cross sectional area.
at least that'd what I'd think
-Mike
Old Mar 31, 2005 | 04:12 AM
20"svt's Avatar
Old Mar 31, 2005 | 04:33 AM
Faster150's Avatar
usually they twist up like a candy cane before they break but heh cool:-p
Old Mar 31, 2005 | 04:37 AM
20"svt's Avatar
Got Torque??
That pic is from RAMAIRSVT's truck...
Old Mar 31, 2005 | 08:15 AM
Red03SVT's Avatar
ohhh, they're hollow... almost forgot. in that case, a breakage in the middle wouldn't be uncalled for
-Mike
Old Mar 31, 2005 | 10:29 AM
SVT F15O's Avatar
Mine failed at the rear joint. Was pretty ugly. -Mat-
Always carry a spare with me to the track, just in case.
Old Mar 31, 2005 | 10:37 AM
LightninMike's Avatar
i think you should be 12" away from the front u-joint and mount there
Old Mar 31, 2005 | 11:21 AM
D Davis's Avatar
Somewhere very close to that(can't remember exact) but it can be found in the NHRA or IHRA rules.
I think original reasoning for ds loops"was, decades ago" to keep the ds from coming thru the floor and getting legs, or possable digging in and catapualting the rear, sending you out of contol, also if it let go in the rear it would slide out of the trans and slide off to the side. at least it seemed good back then, LOL
the regulations tell you where they must have them mounted (if required) to be legal at the track.
some also make rear loops, if you want extra protection
Just keep it safe and have fun
