Question for anyone using the SCT Excalibrator.
Old Mar 28, 2005 | 01:47 PM
NTIMD8's Avatar
Originally posted by nineseclightnin
Did you even check to see if it will fit upside down?
If the units power light isnt coming on when hooked up to the cable from your laptop, there are only two things that could be wrong, the unit is bad or the cable is plugged in upside down. The cable from SCT is not as "cut" at the corners as a normal serial cable and can be made to fit upside down.
Seriously, go check and see if it fits that way and you may find your problem without overthinking whats wrong.
Steve A.
Yes I checked after oyu said it may be in upside down but as mentioned it only goes in one way and I did have it in the right way.
