Valve Cover Opinions
Ok (flame suit on)
Let me have it.
The pics attached are my homage to the GT in my motor build.
Let me have your honest opinions - even though they don't matter - I'm still puttin' em on
Herb
Let me have it.
Herb
Thanks!
Not yet, but I'm still thinking.
I may do the block in the same blue and I am sota thinking about the top of the wire loom covers that parallel the fuel rails.
Herb
Herb
I'm not talking about the actaul wire looms, but the plastic pieces that sit atop the valve cover (attached to two studs per side) that contain the taped looms for coil packs and injectors. The covers on these have a 'ribbed' look much like the center of the stock valve covers. They look sorta like big extruded aluminum fuel rails.
They are the stock plastic valve covers - all illusion and magic!
There is a base coat of a texture metal finish (to give the cast aluminum look) followed by a mostly flat (eggshell I guess - flatter than satin) color coat.
The 'ribs' are actually painted on with a metallic paint (can - not areosol) after very careful masking. This paint looks like the old 'chrome' spray paint - very prismatic and needs stirring constantly.
The overall color/texture effect is actually quite similar to the coating on the real GT covers and as a bonus, an aluminum color will show through if it gets scratched!
Herb
Herb
Thanks for the compliments guys!
SAJEFFC - installed price is a whole bunch
There not that hard to do - I can help you with it, if your interested. Really just some degreaser, sandpaper, masking tape and 4 different cans of paint. I can give you a tutorial.
RED 92 - lemme see if I've got something going on already - What time you heading out there?
mikeyss - I will definately post pics of the finished product (and several leading up to it. You've got to be patient though - My heads won't be in my hands until sometime in early May. I'm going to do some engine compartemnt detailing in the meantime.
Herb
There not that hard to do - I can help you with it, if your interested. Really just some degreaser, sandpaper, masking tape and 4 different cans of paint. I can give you a tutorial.RED 92 - lemme see if I've got something going on already - What time you heading out there?
Herb
Originally posted by BMWBig6
I like them. It's too bad our motors are installed halfway under the cowl and buried under a bird's nest of hoses and lines.
