Eaton S/c
Old Mar 20, 2005 | 07:10 AM
mjg11's Avatar
Question Eaton S/c
Are the eaton S/C the same from 99- 04 ? Same bolt pattern.
Old Mar 20, 2005 | 07:14 AM
wjm5806's Avatar
No they are not the same bolt patterns...99-00 have a different pattern than the 01-04 models. But the 01-04 can be redrilled to fit the 99-00 manifolds.
The 99-00 models can not be changed to mount to the 01-04's manifolds.
Old Mar 20, 2005 | 07:17 AM
mjg11's Avatar
Eaton S/C
Thanks for the help .
Old Mar 20, 2005 | 07:20 AM
mjg11's Avatar
Eaton S/C
Is there any way to tell just by looking at it .
Old Mar 20, 2005 | 07:58 AM
wjm5806's Avatar
Yes there is...the one on the left is a 99-00 model and the right side is a 01-04 model. You can see the difference in the bolt bosses.
Old Mar 20, 2005 | 11:51 AM
mjg11's Avatar
Eaton S/C
Thank you for the information.
Old Mar 20, 2005 | 12:30 PM
bacamino's Avatar
the one i pulled of my 2000 looks like the one on the right with the larger mounting tabs but they are drilled like the one on the left. so im guessing that mine could be drilled to fit both just curious im going to sell mine now that im getting the kenne bell and dont want to give any members any false info.
thanks
Victor
Old Mar 20, 2005 | 01:42 PM
Robert951's Avatar
My '00 had the blower bottom with the extra pad material - piece of cake to re-drill for my replacement '02 manifold I installed (when my I/C finally let go). Just transfer punched the hole positions using a base gasket, drilled it & bolted it down. No problem.
Robert
Old Mar 20, 2005 | 03:02 PM
mjg11's Avatar
Eaton S/C
BACAMINO are you interested in selling yours ? If so you can reach me at mjg11@optonline,net
