Blower belt advice needed...
I want to change my lower pulley from a 4lb. to a 6 lb. unit. (Metco)
My upper pulley is a stock Eaton.
I do have the newer style Metco auxiliary idler kit, which the instructions say to use a belt 1" longer than before the kit.
I don't want to break the tab off the tensioner, I would prefer to have the correct length belt instead.
So, with all of that said, what length belt should I buy?
Thanks for any advice...
Re: Blower belt advice needed...
Scott
Thanks for the reply.
I looked and I have a 68.5" Gatorback on the truck now... I wonder why such a long belt for just a 4 lb. lower ??
That is what was shipped with the original Metco, from one of our supporting vendors ??
Art -
Thanks for looking at it for me... The 6 lb. pulley is on the way !!
jboss10 -
Why would you break the tab (or anything else for that matter) when all you have to do is get the right length belt ?
Ford designed the blower drive system (with input from Eaton, I'm sure) to apply a certain amount of pressure on the bearings in the blower, idlers, etc. Why alter that to save $40 ??
jboss10 -
B - No problem....Anytime...so I guess we are going to Sam this weekent for some tuning ??? It will be interesting to see what you put down w/ basically identical mods to mine - the accufab tb...
