Which MT steet ET for stock Bolt ?
Should I get 26/10.50/16 (25.9 " tall)
or 26/11.50/16 (26.2 " tall)
for a basically stock Lightning ?
If 11.50 too big ..add power :^)
with 16 x 10 steel wheels... package is $624.00
Seriously will I break anything with a large slick with stock power ? I'd appreciate any tips/insite...
Tx
Tx
Ford also want $ 129.00 for a stock wheel to match the spare
front skinnies.....spare plus ..new wheel and tire...
any option on "matching" front wheels ....that is less in cost ?
Decal on door EL Cheapo Racing Team :^).
I run 26 x 11.5" ET streets on 16 x 8" AR baja and give them a big
I would say that you'll need a traction bar. Not so much to plant the rearend... as what's more important is not over rotating the rearend and putting the driveshaft in a bind.
On my web page is a pic of me launching on those tires along with some long tube traction bars. You can clearly see it diggin in REAL good.
Rich
Rich
As others have said traciton bars are a must with slicks. I have a 99 also so the 26" slicks will work best for our 3.55 gears until you run low 12's then you need to switch to 28"s. I run the lakewood traction bars wich you can get threw JEGs for $94 and 26x10.5x16 MT Ets on 16x8 wheels so the contact patch is flat. On my Mickey thompson ets i heat them up very well and run 1.95 sixty foots. My slicks are still new and im just learning how to lauch so i know there is alot more i can get out of them. As long as youve got the traction bars you shouldnt have worry about breaking anything.
