Blown Motor Club 2
Old Mar 13, 2005 | 11:08 PM
bacamino's Avatar
Post Blown Motor Club 2
Well here is a little update I finally got the motor pulled and it was as I expected shot to hell
Almost ready to come out
A little persuasion
Its coming out
Old Mar 13, 2005 | 11:09 PM
bacamino's Avatar
And its out
Now for the CARNAGE
Passenger side with pan
Passenger side with pan removed
Old Mar 13, 2005 | 11:10 PM
bacamino's Avatar
[Oil Pan
Driver side hole
there is more in my gallery
will keep you updated as progress continues
Old Mar 13, 2005 | 11:49 PM
tlfwatch's Avatar
Question NICE SIZE HOLE
Originally posted by bacamino
[Oil Pan
Driver side hole
I BEEN THERE AND DONE THAT.
Old Mar 14, 2005 | 10:35 AM
RED 92's Avatar
bacamino, wheres the pic of your new motor ?
Old Mar 14, 2005 | 12:44 PM
bacamino's Avatar
hopefully ill have pics of it this weekend
Old Mar 14, 2005 | 08:26 PM
AZBLACKMONSOON's Avatar
I'm doing the same thing this week pulling my Sean Hyland , (built ) Piece of crap motor and reinstalling the stock motor. It looks cold there ,NJ , nice 72 degrees here and working in shorts.
Old Mar 15, 2005 | 09:30 AM
bacamino's Avatar
72 degrees i wish i was not to bad during the day but the temp drops fast at night. i just want to get it all done before it gets real nice out so i can drive it.
damn motor
Old Mar 15, 2005 | 09:54 AM
TrackBeast's Avatar
How has your experience been with Sean Hyland? I thought he was a good builder. In fact, I was thinking of ordering an engine from him.
Red
Old Mar 15, 2005 | 10:22 AM
I bought a long block with ported heads and cams, upon first fire up the it ran for 20 seconds and broke the keys out of the keyway of the cams,had it towed to my mech 55 miles away, i had stock cams installed, checked compression for bent valves, everything was fine, Ii fired up and ran , drove it home 55 miles next morning started it and it had a knock in it that never went away. Sounds like a diesel. Traced it down to 2 cylinders by unpluging the injectors, either loose wrist pins , or piston slap because of the possibilty they used centered wrist pin pistons ,that are not offset 50 thousands like stock. Won't know till i get it apart. Also oil started leaking into the coolant after a few hundred miles. Motor runs strong ,sounds like crap. Looked into legal action but them being in Canada is alot of extra red tape, just cheaper to fix it myself. Thank god i kept the 9000 mile stock motor. If there is one thing i can do, is give my expeirence about SHM to others and hopefully they won't make the same mistake as me, go with one of the big 3 builders.
