Need help on fog mod
Old Mar 12, 2005 | 07:03 PM
Boostin01L's Avatar
I did the fog mod just like the instructions(cutting) the tap down but it still will not work in the parking lamp position.
I know I cut enough down just the the headlight part.
Anyone know of something else to try/help
Old Mar 13, 2005 | 12:50 AM
Boostin01L's Avatar
anyone got an idea to help me?
They work like normal but not in parking mode
Old Mar 13, 2005 | 03:44 AM
03graylightning's Avatar
I think you have to connect the #2 and #12 wires together
Old Mar 13, 2005 | 09:00 AM
clonetek's Avatar
check this out for some more info:
https://www.f150online.com/forums/sh...ight=fog+light
Old Mar 13, 2005 | 03:18 PM
Boostin01L's Avatar
Brook does that mean you HAVE TO splice the wires together? I just want the park and fogs not the high beams
You just use a jumper right?
Rick
Old Mar 13, 2005 | 05:41 PM
scv8's Avatar
Yes, in order to run the just the parks and fogs together (no heads) you need to splice #2 and #12. The park position doesn't power the fogs from the factory, like the auto position does, so you're splicing power from the parks to the fogs.
Old Mar 13, 2005 | 05:52 PM
Fast Gator's Avatar
Rick
I wasn't going to answer in this, because I forgot what the wire #'s were. But thats what I did, no modding the headlight switch, just splice a jumper between the wires (2 & 12). This way, my fogs are on with the parking lights and also with the automatic lights. 3 yrs running that setup, with no problems
Old Mar 13, 2005 | 07:44 PM
Boostin01L's Avatar
Ok now they are on with parks. I put a jumper between 2,12 wire I also did the ramp Thought youjust had to do one or the other not both.
Thanks for the help everyone.
