sludge in valve covers
Old Mar 10, 2005 | 06:36 PM
00rsvtl's Avatar
Question sludge in valve covers
over the past couple of months i have been getting a heavy build up of some type of sludge in the valve covers.my oil seperator was alaways catching this but recently when i remove the oil filler cap all i can see of the valve cover is coated.i do not remember ever seing this before.the last time i changed my oil i used 10w-30 insted of the 5w30.could that be the cause? is this a "bad thing" any info would be appreciated.
Old Mar 11, 2005 | 12:02 AM
Master Of Pain's Avatar
What brand, weight and type of oil are you using? Do you have a lower temp. thermostat installed? Where is your coolant level at? Do you have a chip or tune installed?
Old Mar 11, 2005 | 08:54 AM
wydopnthrtl's Avatar
Ouch... Tell ya what "used to work" back before all these new engine cleaners came out.
drain 2 qts of oil out. put 2 qts of keroseine (sp?) in. Let it idle for about 15 miutes. Change oil and filter. Drive about 500 miles and repeat.
This will clean an awfull lot of that up. THEN! Go with a good oil like mobil 1 fully synthetic. And by all means stick with the new brand you choose.
Rich
Old Mar 11, 2005 | 09:04 AM
l-menace's Avatar
What about Seafoam?
I've read alot about that. seems to be a wonder/magic product
Old Mar 11, 2005 | 09:05 AM
l-menace's Avatar
by any chance do you see LOWER oil pressure?
Old Mar 11, 2005 | 09:18 AM
RED 92's Avatar
Re: sludge in valve covers
I would look no further than your oil separator.
Old Mar 11, 2005 | 12:09 PM
00rsvtl's Avatar
i normally use mobil1 5=w30.last oil change i used mobil 1 10-w30.i do not remember seeing any of the sluge (other than what the oil seperator caught) when removing the oil cap and looking inside.i do have a chip in the truck.do not know what the oil pressure is.as far as a thermostat i have not added one since i have owned the truck.i bought it used.the coolant level is fine i have been watching that for a long time.
Old Mar 11, 2005 | 12:26 PM
l-menace's Avatar
you have a '00 lightning?
Has the innercooler been replaced? Is your I/C fluid Level OKAY? have you ever had to refill it?
Old Mar 11, 2005 | 12:35 PM
00rsvtl's Avatar
i have a 2000 l.i/c fluid level is ok.i have cleaned the i/c before.it is marked as being instaled in 01 for the recall.
