stock lightning and my first mods
Old Mar 8, 2005 | 01:13 PM
Oneevil01's Avatar
So far i am lookin to order the 4lb lower the predator JLP ait induction kit and a ftvb ... what else might i want to start with
Old Mar 8, 2005 | 01:22 PM
BigSVT's Avatar
some colder plugs to go w/ that 4#er, some NGK tr6's would do the trick, or some denso's. (IT-22 i think) Denso's are a lot more $$. also get the ford 4x4 tranny pan w/ the ftvb, it holds a little more tranny fluid for extra cooling.
Old Mar 8, 2005 | 01:38 PM
tlfwatch's Avatar
SINGLE BLADE THROTTLE BODY
single blade throttle body is also a must have
Old Mar 8, 2005 | 01:53 PM
Falcon11's Avatar
This thread pops up every other day. I'm sure you can find plenty using the SEARCH.
Old Mar 8, 2005 | 02:30 PM
Tim Skelton's Avatar
Re: SINGLE BLADE THROTTLE BODY
Bad advice.
Good advice.
Old Mar 8, 2005 | 03:01 PM
BigSVT's Avatar
i have read good things about the bbk dual balde t-b. if u search bbk vs accufab or something like that, you ought to find some dyno numbers i think.
Old Mar 8, 2005 | 07:09 PM
Floridalawdog's Avatar
I just put on a bassani exhaust a couple of days ago. It has a great sound and makes it that much more fun to drive. I fully reccomend it.
Old Mar 8, 2005 | 07:20 PM
Cub Cadet's Avatar
First off you need a chip to run all of this. I suggest Mike Troyer at Troyerperformance.com.
Second, a throttlebody is a waste of money unless you are making big HP. This has been discussed here over the years. The only reason I have one is because it was a great deal (bought used), and it sounds cool on throttle tip in. Other than that, it is a waste on my truck... and I am running 12.40's.
