Is this normal when i stomp on the gas ????
Old Mar 8, 2005 | 01:06 PM
Oneevil01's Avatar
I have a 01 bone stock lightning and ever since i got it when you stomp on it in 1st or 2nd it pulls hard then around 3-3500 there is a lil delay then it gets going again .. is this normal or is something ****ed up ? I am about to cancel my warrentee so i can mod the truck but i want to make sure something isnt screwed up
Old Mar 8, 2005 | 01:23 PM
camcojb's Avatar
Re: Is this normal when i stomp on the gas ????
Sounds like the converter locking up; doesn't do it in first gear, but does it in all others?
Jody
Old Mar 8, 2005 | 01:26 PM
Oneevil01's Avatar
No it only does it in first
Old Mar 8, 2005 | 01:27 PM
camcojb's Avatar
Then I would say that's not normal. Fuel filter is one idea.
Jody
Old Mar 8, 2005 | 01:36 PM
Konig's Avatar
stock torque reduction maybe?
Old Mar 8, 2005 | 02:32 PM
Oneevil01's Avatar
I have no idea .... i dont see how its something too big
Old Mar 8, 2005 | 03:32 PM
brain bypass's Avatar
maybe switching from closed loop to open loop?
Old Mar 8, 2005 | 03:42 PM
Shocked's Avatar
I would lean towards the fuel filter as well, also how much gas did you have in the tank when it does this? Sometimes I have heard of fuel starvation from the fuel being low.
Old Mar 8, 2005 | 06:59 PM
Oneevil01's Avatar
almost a full tank its done it a few times and its always around the same rpm
Old Mar 8, 2005 | 07:41 PM
92Saleen's Avatar
My Lightning did the same thing. It was the spark plugs. Changed them out and no problems. Worth a check.
Old Mar 8, 2005 | 08:03 PM
Cub Cadet's Avatar
Disconnect your boost bypass.
Old Mar 8, 2005 | 08:30 PM
FunTruck's Avatar
Mine's an 02 and has done the same thing since new. It's stock except for an Air Filter and a Factory Tech Valve Body.
Don't worry it's just the Torque Convertor locking up. I've done a search on here and it's nothing to worry about.
Old Mar 8, 2005 | 08:37 PM
Cub Cadet's Avatar
Do either of you have your boost bypass disconnected? That solved the issue for my 02.
Old Mar 8, 2005 | 09:07 PM
Agent00GT's Avatar
I have a pretty much bone stock 01'. It does the same thing. Mine will do it in 2nd mostly. I think its just torque reduction. I did the boost bypass mod too. It still does it.
Old Mar 8, 2005 | 11:33 PM
Oneevil01's Avatar
maybe after i do the 4lb lower and reflash the computer it will fix it
