Transmission Question?
I just got my FTVB w/4X4 pan and filter yesterday from Tim @ Chickenears. I had it withnin 24 hours of when the order was prcessed. That is what I call customer service!!!!!
I'm going to install it this weekend, my question is when I drain the tranny and converter how do I A. fill the converter and B. How many quarts will it take to fill them both up?
Re: Transmission Question?
Originally posted by 99RedSVT
I just got my FTVB w/4X4 pan and filter yesterday from Tim @ Chickenears. I had it withnin 24 hours of when the order was prcessed. That is what I call <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=24&k=customer%20service" onmouseover="window.status='<a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=24&k=customer%20service" onmouseover="window.status='customer service'; return true;" onmouseout="window.status=''; return true;">customer service</a>'; return true;" onmouseout="window.status=''; return true;">customer service</a>!!!!! :rocker: I'm going to install it this weekend, my question is when I drain the tranny and converter how do I A. fill the converter and B. How many quarts will it take to fill them both up?
If you want to flush it, here is a thread where I explained how I did it. It's pretty easy. You will want to have 8 quarts come out of the trans cooler line in order for the converter, trans cooler and lines to all be flushed out with new fluid. If you do it this way, you will be around 17 quarts of new fluid put in, which is what the tranny holds dry.
https://www.f150online.com/forums/sh...postid=1563114
For those who want to do it, we now have Factory Tech MERCON fluid, a special synthetic blend some good friends mixed up especially for the 4R100... it comes in a 5 gallon container which is real convenient for doing the DIY fluid flush.
G
G
Originally posted by LockportDon
Can I use a FT VB with my Superchip ?
Can a regular guy installed it or special tools skills required ?
Tx
Tx
Since your truck is a 99 model, you should have a drain plug in your converter. There will be a rubber plug in the bottom of the bell housing that you'll need to remove. You can take a large screwdriver or small prybar and rotate the torque converter until you see the drain plug. Once you drain the pan and converter, it should take around 16-17 quarts to refill the entire tranny.
