Gapping tool
Old Feb 19, 2005 | 04:46 PM
Fowl's Avatar
Gapping tool
Which spark plug plug gapper do you use on your lightnings. The tapered edge or wire gapping tool? I am in the process of gapping my plugs. I have both of the gappers and I am wondering which one is most accurate.
Old Feb 19, 2005 | 06:49 PM
Master Of Pain's Avatar
Re: Gapping tool
Wire or blade feeler. The wedge will damage fine wire electrodes, however still works great for Champion plugs that go in lawn mowers.
Old Feb 19, 2005 | 08:57 PM
dealerjim's Avatar
Re: Re: Gapping tool
Originally posted by Master Of Pain
Wire or blade feeler. The wedge will damage fine wire electrodes.
Yep, I learned that the hard way. Had 6 Denso plugs gapped and changed and while gapping the 7th, I broke the tiny little electrode off using a wedge type guage. After cussing and screaming for about 10 minutes, I took the other 6 out and put TR-6's back in. That was back when it would take me nearly an hour and a half to change the plugs.
Old Feb 19, 2005 | 09:41 PM
Fowl's Avatar
Thanks for the response guys, but which one is more accurate because both give different readings when gapping the plugs?
Old Feb 19, 2005 | 10:37 PM
dealerjim's Avatar
Like MOP said, the wire or feeler guages work good.
Old Feb 19, 2005 | 10:46 PM
Fowl's Avatar
Old Feb 19, 2005 | 11:13 PM
NorCalLightning's Avatar
This is the one my friend has. He used it today to do a spark plug change on my truck. Works great!!!
You can buy them here Jeg's
Steve
Old Feb 19, 2005 | 11:21 PM
camcojb's Avatar
Steve
I'm the friend above. The one above is very nice because in addition to getting an exact gap, it keeps the entire electrode parallel for a straight gap across the plug, not tight at one end and loose at the other.
Jody
Old Feb 19, 2005 | 11:53 PM
Ayrton's Avatar
Those are from Jacob’s Electronics and you can get them several places, as mentioned Jegs, Summit, etc…
Old Feb 19, 2005 | 11:56 PM
camcojb's Avatar
Yep, I owned a speed shop in the early 80's and I was their first dealer in the Sacramento area. Had some cool ideas and I've always kept this tool, works very well.
Jody
Old Feb 20, 2005 | 12:06 AM
Talking
Jody
Cat's out of the bag now!!!
Steve
