KB pulley bolt problems
Old Feb 19, 2005 | 12:47 AM
Casey02L's Avatar
Anyone had trouble getting the KB pulley bolt out? We tried the holder tool, and a cheater bar, but that didn't work. Could an impact be used?
Old Feb 19, 2005 | 05:42 AM
Bad as L's Avatar
Casey
You might want to hold off on the impact....your rotor drive gears will like you for that
Personally I went though several different hex drives before I found one that fit the bolt perfectly and I always torqued the bolt to 80 ft lbs and never used any lube on it. I couldn't find any information in the KB intructions saying I had to lube it so I didn't.
I also never had a problem getting the bolt on and off.
Did you put anything on it like loctite ??
Dale
Old Feb 19, 2005 | 10:38 AM
Casey02L's Avatar
I've never had it off; it is the one installed from KB. It is a standard thread correct? So, looking at you turn it counter clockwise to take it off?
Old Feb 19, 2005 | 10:51 AM
2bscrewed's Avatar
Yes it's standard. I've never had a problem and have also never lubed it. I change pulleys at least once a month though.
