pulley install
Old Feb 16, 2005 | 09:36 PM
Fowl's Avatar
pulley install
Is there any thread with detail pics and instructions on how to install lower pulley? will be adding a 4 lber soon. Instructions that came with metco are not really detailed. I need the fun factor from my truck
Old Feb 17, 2005 | 10:11 AM
Fowl's Avatar
No reply, but that is Ok. I found one on NLOC.
Old Feb 17, 2005 | 10:25 AM
JeffsLightning's Avatar
Sorry we were not quick enough....
Old Feb 18, 2005 | 02:32 AM
Marc Carpenter's Avatar
If you can't follow the instructions that came from Metco, you better not attempt to do this install. I found their instructions to be clear and very easy to follow....
Look around and do a search and you shall find them pretty easy if you really need them.
Old Feb 19, 2005 | 07:57 AM
Rob_02Lightning's Avatar
I can do a quick "How To" on that : o )
STEP ONE, Remove Inspection Cover.
STEP TWO, Remove a Convertor Nut and use supplied Bracket to Lock Convertor to Bell Housing.
STEP THREE, Remove the Cage Bolts.
Old Feb 19, 2005 | 07:59 AM
STEP FOUR, Remove Pulley by using supplied Allan Key Socket.
STEP FIVE, Remove the Original Lower Pulley and Cage.
STEP SIX, Install the New Pulley using (3)supplied Allan Bolts.
Old Feb 19, 2005 | 08:01 AM
REMOVE BRACKET
Put a Belt on
AND YOUR DONE
Old Feb 20, 2005 | 02:22 PM
Fowl's Avatar
Thanks Rob all i needed was pic's to go with the instructions. It is much clearer now. Will let you guys know the results
Old Feb 20, 2005 | 02:45 PM
NorCalLightning's Avatar
Great instructions Rob. The pics really help. Remember, DON'T FORGET TO TAKE OFF THE CONVERTER LOCKUP BRACKET.
Sorry for the caps, I just wanted to stress that to folks
Steve
Old Feb 20, 2005 | 05:11 PM
tallimeca's Avatar
another one
make sure you use a 14mm 6 POINT socket to take the convertor nuts off to use the strap.
Was helping someone with a pulley this weekend and they didn't have a 6 point, needless to say, all the bolts were on there tight and with the 12 point, the nuts were doomed.
Old Feb 20, 2005 | 09:34 PM
Fowl's Avatar
thanks for the heads up. I have both sockets so I will use the 6 point.
Old Feb 21, 2005 | 03:18 PM
OCSSleeper's Avatar
now, if you for some reason need to put the stock caged pulley back on, can you tell that an aftermarket pulley WAS on there if you do a need job with 6pt sockets?
Old Feb 21, 2005 | 05:38 PM
tallimeca's Avatar
no
the 6 point socket is to ensure that the convertor nuts don't strip when you are trying to remove them. Mine came right off no problem but the one i did last week would not come off. When we originally put the pulley on, i had to put a floor jack under the handle of the ratchet to break one loose. But who ever installed the built tranny put a hurtin on the nuts.
The 12 point just runs more of a risk of stripping.
Old Feb 21, 2005 | 06:20 PM
Master Of Pain's Avatar
Dude,
Before you do this proceedure, be advised that the stock pulley is a clockwise-off threaded piece. Get a nice, long breaker bar and wear gloves, and pad your forearms with something, because when it does break loose, your breaking torque is going to carry your body parts straight into a new realm of pain, so be sure you've padded yourself as advised earlier. You might find yourself ripping your backside open with the strain. That's why lesser men and women cannot own Lightnings!
By the way, the "quick change" aspect of the lower kits is so NOT true. Complete pullies are just as hindered as hub pullies by the PITA stock fan.
Old Feb 21, 2005 | 07:34 PM
Fowl's Avatar
Thanks Master of Pain,
Hope I dont feel too much pain
