"installing Pyrometer In Manifold
Old Feb 10, 2005 | 10:41 PM
tlfwatch's Avatar
"??? Are they any certain place that need to be tapped or drilled are they already a place to screw the pyrometer probe into the manifold area ?? thanks
Old Feb 10, 2005 | 10:52 PM
MISTERgadget's Avatar
you have to drill and tap it. if oyu have longtube headers, you will need to weld a bung to it.
Old Feb 10, 2005 | 11:19 PM
Casey02L's Avatar
A buddy of mine tried that; it didn't work. Basically it is measuring heat. Well; the manifold radiates heat, and screws up the readings.
Old Feb 11, 2005 | 06:51 PM
tlfwatch's Avatar
THANKS
THANKS FOR THE INFO
Old Feb 11, 2005 | 07:18 PM
Neal's Avatar
HI!... If your talking about installing a EGT (exhaust gas temp) sensor, then make sure you install it on the #5 cylinder. That would be the driver's side front cylinder. It is known as running the leanest of the 8 cylinders.
Old Feb 12, 2005 | 12:14 AM
chucks bp's Avatar
What is the correct way to drill into the manafold down through from the top or from the side toward the cylender head?
