JLP 2005 Project Underway!
About time someone spent some time/effort/$$ on the suspension. Just because you race in a straight line line doesn't mean the suspension isn't important. My bet is you will see more results (once dialed in) than adding another 250hp. Box in as much of the frame as you can. Lots of X-braces. Stepup the rollcage as well. At least you can make it a semi-tube frame. Adding to the cage will help prevent the twisting.
Re: JLP 2005 Project Underway!
Originally posted by JohnnyLightning
05 is going to be a fun year
But as someone that makes a living with a torch and a welder, seeing someone use a cutting torch with minimum eye protection, and no hand protection, is just plain stupid
Re: Re: JLP 2005 Project Underway!
Originally posted by Fast Gator
Go Johnny Go!
Go Johnny Go!
