lowered the rear...now wheel hop?
Old Jan 31, 2005 | 03:06 AM
svt_2004's Avatar
hi guys i lowered the rear of my truck, adjusted the pinuion angle to where i get no vibration, but now on a hard launch i get some wheel hop, is the only way yo correct this by adding traction bars, my truck is only lowered a 3.5 inches in the rear, anyone else experience this??
Old Jan 31, 2005 | 03:22 AM
birdy111's Avatar
do you know what your pinion angle is set at? i think for best traction results you want it at about -3 degrees? i recall a discussion about this a little while ago, but I don't know if that would give you vibrations at certain speeds or not?
Old Jan 31, 2005 | 09:59 AM
MHMCGILL's Avatar
Re: lowered the rear...now wheel hop?
How did you lower it? Shackles, springs, what?
Old Jan 31, 2005 | 10:10 AM
TampaBlack99's Avatar
Traction bars
Old Jan 31, 2005 | 12:23 PM
svt_2004's Avatar
its lowered with one, leaf removed, 3" shackles and removed factory shims, like i said i have no vibration at high speeds or low speeds, everything is good, until i launch real hard
Old Jan 31, 2005 | 12:41 PM
MHMCGILL's Avatar
Originally posted by TampaBlack99
Traction bars
With a leaf removed you can wrap it up much easier which will result in wheel hop. Also just make sure you didn't overtighten the shackles. If I were you I would not launch hard until you get Traction Bars. Might want to think about a DS loop while you are at it. Good luck.
Old Jan 31, 2005 | 12:54 PM
OD1010's Avatar
sorry svt_2004 im not trying to hijack your thread!! but my question is for MHMCGILL, you said that svt_2004 might want to look into the traction bars and DS loop, what is DS loop?!?!? i did a search on it but DS is to short to search for! thanks and sorry again to svt_2004
Old Jan 31, 2005 | 01:06 PM
MHMCGILL's Avatar
Sorry about that. DS is short for drive shaft loop. Hard launches, wheel hop, modded motors all increase the chance for snapping a drive shaft off resulting in major damage or possible injury. The loop prevents the front of the Drive shaft from digging into the ground, among other things.
Old Jan 31, 2005 | 01:25 PM
svt_2004's Avatar
so what do most lowered guys do? my truck isnt even that low...im sure there are guys in my situation without ds loops, and traction bars, its just a daily driver, how tight should the shackles be? do they move?
Old Jan 31, 2005 | 01:49 PM
RustySocket's Avatar
By removing a leaf youv'e made it just that much easier for the torque of the motor to wrap the axle. Traction bars will limit the travel and stop excessive wrap. DS loop is smart insurance imho.
Keep your foot out of it or it's gonna bust a u-joint.
Old Jan 31, 2005 | 02:16 PM
Tim Skelton's Avatar
so what do most lowered guys do? . . .
Most lowered guys have not removed a leaf.
Old Jan 31, 2005 | 02:32 PM
Traction Bars
Old Jan 31, 2005 | 05:15 PM
wydopnthrtl's Avatar
svt_2004, you'll be ok just GET SOME traction bars on it asap. I've got a 3" shackle in the rear and some JL 58 long tube lift bars. Only issue you might have is them slightly hitting the mufflers exiting pipes.
(my spin techs clear ok after a slight adjusting)
Rich
Old Jan 31, 2005 | 05:47 PM
octogon169's Avatar
lakewoods are cheap and easy. $100. done.
Old Jan 31, 2005 | 06:24 PM
B-Man's Avatar
Cool
I used to get wheel hop with my L, even before I modded it.
JLP fixed that problem for me !!!
