Grill mod done!!!
Old Jan 31, 2005 | 12:37 AM
Redlightn 02's Avatar
Old Jan 31, 2005 | 02:55 AM
FLBigDog's Avatar
I did it as well, its hard to beat for the price.
-Patrick
Old Jan 31, 2005 | 03:04 AM
svt_2004's Avatar
will it ruin the grill if you ever want to take it off?????
Old Jan 31, 2005 | 04:19 AM
FLBigDog's Avatar
I doubt it, I'd imagine with a little bit of simple green or something like that any residue could be wiped off.
-Patrick
Old Jan 31, 2005 | 10:32 AM
Actually it does double duty, while making your grill look custom it also protects it from chips due to road debris and if the molding gets damaged just replace it with another piece and it will look as good as new. If you had a Harley grill and it got damaged it would cost a lot to fix or replace so you can't beat the bang for the buck.
Old Jan 31, 2005 | 11:03 AM
johnathanh's Avatar
Hi guys
Where can i buy the 2001 up lightning grilles?
Any websites?
Johnathan H
Old Jan 31, 2005 | 11:37 AM
BMWBig6's Avatar
Re: BOB
Originally posted by evo
How wide is the contact area on the molding? Looks good!
The 3M adhesive strip is about 1/4" wide. The actual chrome trim is 3/8" thick. It's just large enough to cover the "dome" of the grill contour.
Old Jan 31, 2005 | 12:19 PM
svt_2004's Avatar
i was just worried about it taking the finish off when you peal the molding off thats all, so you dont thionk it will ruin the finish of the stock grill?
Old Jan 31, 2005 | 12:45 PM
OD1010's Avatar
do you guys have to remove the grille while doing this mod or so just put the molding on while grille is in place? i might also add they look sick!!
Old Jan 31, 2005 | 01:41 PM
RED 92's Avatar
yes it could peal, the finish in some areas .... a gray touch up would correct the finish. I was not concerned with the cheap gray finish provided by ford and painted my grill black and then put the chrome strips on it about a year ago.
Old Jan 31, 2005 | 09:03 PM
svt_2004's Avatar
what did you guys do around the BOTTOM of the ford emblem?
Old Jan 31, 2005 | 09:06 PM
ema100c's Avatar
Some people trimmed the trim to fit underneath the oval. Right now I just have mine raised out a bit in order to keep the trim straight when you are looking at it head on.
Old Jan 31, 2005 | 09:08 PM
svt_2004's Avatar
raised? how? do you have a pic?
Old Jan 31, 2005 | 09:22 PM
ema100c's Avatar
Look at the pics in my album
Appearance mods album
I don't have a side shot of the grill but that is the only position you can see it is "bubbled out" at all to fit underneath the oval. Basically you just have to raise it up a little so that it stays straight with the grill. I have thought about re-doing that middle piece and trimming it to fit underneath the oval but I showed it to several people and they said it looked fine.
Old Jan 31, 2005 | 10:10 PM
svt_2004's Avatar
just did the mod, kicks asssssssssssssss!!!!!!! so easy and cheap! You will need 2 rolls if you want to do the lower grill as well! Looks amazing
