is this fixable?
Old Jan 25, 2005 | 10:34 AM
00Bolt's Avatar
is this fixable?
Old Jan 25, 2005 | 10:36 AM
TampaBlack99's Avatar
How did that happen, you drop the intake?
I would get it welded.
Old Jan 25, 2005 | 10:38 AM
00Bolt's Avatar
guy said when he installed it and put the bolts in it just cracked....
Old Jan 25, 2005 | 11:22 AM
wydopnthrtl's Avatar
It can be fixed. However you'd probably spend about the same amount just replacing it.
It would need to be welded, machine the gasket face, and then repolished.
Rich
Old Jan 25, 2005 | 11:27 AM
D Davis's Avatar
Looks more like they tourqued down 1 side before starting the other.
I'd get some estimates on welding and machineing to make sure it's true, then compare to replacment cost.
Good luck
Old Jan 25, 2005 | 02:07 PM
Mart Man 03 L's Avatar
Man that sucks. I can't imagine the time and or cost of polishing just to have some numb nutts break it. If it was done at a shop and you were paying, I'd make them pay to replace the part. JMO
Old Jan 25, 2005 | 02:11 PM
Struck in AZ's Avatar
Re: is this fixable?
Who in the hell banged on the gasket mating surface and with what???
Old Jan 25, 2005 | 05:15 PM
alpine's Avatar
It was my plenum, I did the polishing myself. When it broke, I decided to just buy one polished from LFP instead of messing with it. I didnt drop it or improperly install it or over-torque the bolts, it just broke. I gave it to Scott and if he can fix it, that would be great because I put alot of time in that piece and it turned out really nice.
